This post may also help:
Restore Store Purchases - General / Frequently Asked Questions - RealDash Forum
Hi,
I wanted to customise and add NoBull dashboard to my android headunit, but since customising it on the headunit is inconvenient, Iâve bought it, customised and exported it to a file on my Mac.
As described here when I tried importing the file in the headunit it complained that I havenât purchased it.
I donât mind purchasing it again on Androit, but would it let me load my already custonised dashboard then? I would like to avoid having to redo it again.
Cheers
If youâre using different stores, like Microsoft, Android and Apple, then yes you need to repurchase the app again.
If, youâre using the same store then the same account has to be logged in, from there you can restore purchases in settings.
A subscription of real dash is not the same as purchasing realdash, but I believe with a subscription you are limited to the number of devices you can have it on and need to remove a device to add a device.
Using a custom dash setup though should work and translate over no matter which purchase option you use.
One thing to note is that if you take our premium dashboard and modify it, it is still our premium dashboard and requires a purchase or My RealDash subscription to use. Even if you open premium dashboard and delete everything, its still a premium dashboard.
If you start a completely new custom dashboard (Edit->File->New), its usage is not limited in any way.
