I have noticed a few bugs / issues in the iOS version so far – iOS 18.5 on an iPhone 14 Pro.
When selecting a gauge and entering the ‘Look&Feel’ menu, the gauge is not downsized to fit in the dedicated preview spot – it is always at 100% size and thus, larger gauges may overlap part of the UI. The UI is still interactive but not visible underneath.
Setting the duration for the “Vibrate” action does not change the duration of the vibration.
Moving a container to the lowest layer (Arrange > Send to Back) while gauges inside that container are still selected will crash the app.
Rotated text in gauges, from the Autoscaling feature, becomes gradually more misaligned the further you go along the sweep angle for some fonts, especially ones with rather tall but narrow glyphs. This may be due to the anchor point for rotation being set to the leftmost point of the generated text box rather than the center, but I’m not sure.
I found a bug with the newer version than 2.4.8, when I connect to the obd2 adapter with Wi-Fi, I should turn off the mobile data, Otherwise the software couldn’t read the data, when I use 2.4.8, there’s no problem like this, can you fix it, I really love this app, and need the new function(Average Fuel Consumption for last 20 km)
I am still stuck to 2.4.9. On OBD2 connection, since 2.5.0, there is no output for RPM, MAP, IAT, vehicle speed, throttle position, STFT% 1 & 2 on default IDs. I tried on debug data view and there are no output.
