Pin To Pin Honda Prelude 1991
i start work MCU6
add inputs
add Ultra Low Power Mode (For start from CAN)
add VPW Reader - Covert to the RealDash CAN
the gained experience will make it possible to make a release in February
My name is Fabricio, I live here in the United States, but I am originally from Brazil. I would like to know if you can develop software for my own digital dashboard.
My car is old, but I would like to modernize it with a functional digital dashboard, with high and low beam headlights, right and left turn signals, open and closed doors,
temperature gauge, speedometer, etc. My car is a Fiat Uno, but I would like to buy the Soffeter that I can modify in the future if I change the make and model of the car.
And if you do, how much would it cost? The endings on my car are analog, just so you know. I would also like you to help me with all the plates I will need.
I await your contact, thank you very much…
How fast do these boot up from a cold start… Not in sleep mode.
boot up from a cold start = 30 sec
onboard Series5 new MCU6
Update 31_01_2025
2 PCS CAN 5 - 1000 kbps 11 or 29 bit ID
speed can be change from app RealDash
onboard battery voltage sensor
2 pcs Input Sensor for fuel tank 0 - 400 Ohm
3 pcs Inputs Sensor ADC 500 - 100 000 Ohm ( can be easy change to Voltage)
3 pcs Inputs Sensor ADC Voltage 0 - 5v ( can be easy change to Ohm)
3 pcs Tacho inputs for RPM
Binary inputs
6 pcs positive sensor
6 pcs negative sensor
15 pcs universal sensor ( can be changed on the positive or negative)
onboard gyroscope
all inputs have protect - your android (or any) device have protection
all data used 1 port usb (RealDash CAN)
there is an expansion slot for starting the panel on a can command or an analog command for a quick start of the panel on an event (for example, the door was opened) - module on base stm32L431
diagram
I have now found the android device itself in retail on AliExpress. you can buy it yourself, but I can’t give any guarantees. you’ll have to trim the touch glass and make the shutters out of a more durable material than plastic - (otherwise there will be glare) - but as a result, you can save money.
In my product, I order a screen with a brightness of 1000 nits from a supplier and use an aluminum chassis. But you have a choice if you want to save money.
Does Single wire CAN work with your system? Also can it do 2 different busses? I have 500k and 33k in my car. I would like to know if your system will work.
Yes, I guarantee a job. you can change it to any speed with special packages (instructions are attached). from CAN 1, the headers are skipped as is. and 30 bits are added from CAN 2.
for example ID 0x186
in CAN Monitor
CAN1 00 00 01 86
CAN2 20 00 01 86
same send from RD to CAN if 30 bit = 0 - to CAN1
if send CAN frame id with 30 bit = 1 - to CAN2
How much is your system shipped to the us?
200 USDT (crypto money) with delivery
This looks very similar in shape to my 2009 Toyota Camry Cluster. Wondering if it’s possible to plug in to or modify to use or if you can develop for my car as well. XV40 is also referred to as Toyota Aurion outside of US.
I accept orders for custom dashboards, it takes an average of four months and 2000 usdt
The dash with 2 screens is nice, is that 2 units or just one with two screens, I want that setup for my OBS truck.
John
I promise to start shooting educational videos, but now is a difficult time, it is very difficult to launch USB cameras on CAR ANDROID devices (UIS 7862 and other).
