Does your hardware handle 2 x USB ports without having to reassign them in the garage everytime?
course - 100% stabity work - but USB device must be with diffent vendor ID
i think you try use same USB - change ID in firmwarre or change chip
I actually bought a new Android head unit on Aliexpress during the Black Friday and it arrived yesterday.
It was identical in size and shape as the one I had before but this was Seicane branded and had a newer Android version. It now connects both USB every time. The Seicane unit always defines the usb ports as USB0 and USB1.
The Old head unit used to keep indexing them as Com 3, Com4 and the would go to Com5 Com 6 etc. I would have to reassign then every time in the garage or hard reset.
Sorry, can not help you
Custom hardware too hard
I have seriously updated the platform
2 PCS CAN 5 - 1000 kbps 11 or 29 bit ID
Binary inputs
6 pcs positive sensor
6 pcs negative sensor
12 pcs universal sensor
Input Sensor for fuel tank 0 - 400 Ohm
Inputs Sensor ADC 0 - 10 000 Ohm - 2 pcs
Inputs Sensor ADC Voltage 0 - 5v - 2 pcs
Tacho inputs for RPM - 2 pcs
Voltage Battery Sensor
onboard gyroscope
This is amazing! I might need your help with my project
Unfortunately, the video is not in English, but you can see how the new feature works starting with RealDash v2.3.8
For your no ECU addon board, does it support K-type thermocouples for EGT temperature sensors?
Is it possible to use one of these screens?
10.25" i can not use
I my warehouse only 12.3" for cutstom order
10.25" Chinas supplier demand min order 50 pcs
sorry, I mean if I order a unit, can I swap the screen myself?
Only 12.3" i can made 1 pcs
As always, it turned out very cool
@Falcon_S I need one of these!! Please can you help?
Hello, please use app Telegram for write me @falcons_s
