So, im wondering if there is a way booting RD on my rpi5 faster than 16 seconds!Pidash can boot in 7 second with a raspberry 5, but i prefer the realdash interface.
I know that it can be in stanby mode and boot really quickly, but im needing some coaching on this
After you disable the Intro, the loading time of the dashboard depends fully on how much assets it has. If you have a lot of graphics and fonts, the loading time can get into several seconds.
It is possible to combine a lot of small images into image atlas to speed up the loading. See discussion here:
What we have found that best performance increase is to use fast SSD drive instead of MMC card for the OS. Then there is some tweaks to ‘slow start’ some of the operating system services. These can get you to ~10 second range, but 5 seconds sounds like heavily customized OS.
Got my Raspberry pi 5 yesterday and starting to build the cluster. I will post what I do for speed. I did put a NVME hat on there and set it to run at gen 3 speeds. Its super quick but I wan to get speeds faster and m ore like its not hacked in the car but a legit install.
Yeah but… i mean do u run bookworm?dietpi? How do u modify it to boot into the desktop in 6 second? I know that if u dont load some service like bluetooth or network connection u probaly boot faster… but 10 second faster?
