Resources for Viewing DTC Freeze Frame and Clearing DTC
On this page: Action and Triggers
What’s the intended implentation of these Actions? If I set-up a button for READ and CLEAR, when I READ, where is the freeze frame written to and how do I access it?
In this post: Display Engine Protection Reason/Codes - Haltech
Can you explain how to use the quick settings in this way?
I’ve since figured out that QUICK SETTINGS refers to the little settings button in the bottom right hand side, when you touch the top of screen and the menu comes up.
The Quick Settings has the following buttons:
  • ERROR CODES - READ
  • ERROR CODES - CLEAR
When I have a DTC code present, and press the READ button, a popup comes up that says “i - No Error Codes Found”
I can read and clear this type of code with other 3rd party apps through the MX+ dongle I’m using, so I think this is a software issue with RealDash. I must need to add my fault codes to my .xml in a certain format?
Would love to know how to do this, if that’s the case!
Unfortunately custom fault codes list would not help here as RealDash does not find any error codes.
To troubleshoot this, your would need to enable debug logging:
Then use the Quick Settings ‘Read Error Codes’ option and upload the debug log from the settings.
In addition we would need to know what is the expected result (the error code) that should come up when errors are read.
